Well my dealer told me to take it easy for the first 80 - 100 miles and stay below 6000rpm, then gradually work up from there. I did get a reply on the oil used which the dealer says to service the bike at 600 miles. Well here is what I was emailed and see what you think.
-Alright, I'll try to keep this short but effective. First, you haven't screwed anything up. The basics: When an engine is assembled, it is put together with a pre-lube, which is like a grease (very thick). The oil that is initially used in the bike is a very light weight oil known as 'breakin oil'. One of main jobs of the breakin oil is to help clear all the pre-lube out of the engine. While all this is taking place, the first 10 miles, 50 miles, 100 miles whatever are the most important in determining how well things are going to work (power, oil consumption, etc.) and how long it will last (longevity). What break-in really is: the process by which all the newly machined parts get used to each other and 'learn' to work together. It is like all the parts in the engine are sanding themselves against eachother. In the first few miles a tremendous (and I mean more than will take place in the rest of the lifetime of the bike) amount of wear takes place. That is why the 'hows' of break-in are so important. All the 'sanded' particles end up circulating in the oil in this most important period of break-in.
I have a very nice '04. When I purchased it, I bought oil and filter at the ame time. I heat cycled the engine at the dealer a couple of times. I rode it home the 'proper' way (if you read Mototune then you know what I am talking about) and changed the oil at 42 miles.
The oil during the first oil change will come out looking like a metal-flake paint job.
The bottom line is: Change the oil as soon as possible. The sooner the better. Tell the guy at the dealer that you understand that the recommended change is at 600 miles, but you would like to do it sooner (now). Tell them you will bring it back for the 600 service too (and do). The second oil change is the second most important as a high level of wear will contine for about a thousand miles.
Make sure that Yamalube 10-40 is used with a Yamaha filter.
After the initial break-in we can talk more about service intervals and other hop up goodies.
Remember: No Synthetic yet! only dino oil. -
