I've finally got my bike back together with the new bodywork, fuel tank, and so forth. We filled up the tank, primed the carbs with some carb cleaner, and fired it up. It cranked and cranked and fired for a few seconds, probably burning the carb cleaner we put in. This led us to believe it was a fuel problem.
We checked all the fuel lines and the fuel filter and they all flowed just fine. Then we took the pump off and ran it using a battery and it worked just fine. After spending a few hours looking over the forums, I believe it's the fuel pump relay that's the problem.
We replaced the wiring harness during the rebuild and were using the relay from the newer harness. I replaced it with the old relay and had no better luck. I still can't think of anything else it could be besides the relay, but it seems odd that two different ones would be bad, especially one that worked before we removed the wiring harness.
I'm totally stumped at this point. If it isn't unusual for two out of two relays to be bad then I guess i ought to order a new one. If that is unusual I might take it to the local Yamaha dealer and get a diagnostic run.
If I order a new relay from off here, I want to be 100% positive it works. Otherwise I'm just wasting money. If anyone has one that fits that bill or knows a bit about these relays, I'd love some help.
