how long do r1s last?
6.4K views 43 replies 32 participants last post by  Red Ballz
i KNOW there are a NUMBER of variables to this question, but in general, i was just wondering: how long have people's r1s lasted for, miles and years wise?
ive got an '03 that just turned 30k and it seems to be doing fine. i ride it everyday (as i odnt have a car and live in FL), and change full synthetic oil every 4k, plugs every 9k or 10k and the other normal maintainance. other than maybe a fork rebuild (new springs or fluid or whatever), just in general, how long will it last?
for instance most cars one could say last around 100k is this the same for bikes or are we looking more like 40k?
i mean ive seen bikes that were 10 years old with 48k that have ended up dying but it was generally from age (seals gaskets etc) [but that was up in new england] but then again ive never seen a 4 year old bike with 50k on it, lol. anyway, i was just wondering what people's experiences have been...
mine is under 4 years old with 30K and runs better than it ever did!
Take care of them correctly and100k isn't out of the question... I'll keep you posted my 04 will stay with me as long as I live...
Take care of them and do the maintenance and they will last. The stator tends to burn out on the '02/'03's around 20K.
my gf likes nuts...sweet ones at that:rant
Back on topic... I had stator and rectifier probles every 10k on my old r6...man that pissed me off, every year one of them crapped out
my 00 had over 55k last time i saw it. sold it with 4k miles and guy rode crap out of it. in 100k miles, u might need stator, starter, few tidbits. but all in all should be good for that and more if u take care of them.
Just a FYI.... Cars last WAY longer than 100k miles. Most bikes will go to the junk yard from a crash well before they wear out. Most modern cars will go in the 250-350k range before needing major work over there value. That is of course if some one does there part to take care of it.
#11 ·
yeah, i know i just ment in general, shit my 74 blazer has 306k on the original motor, im just saying a 100k is a safe bet before needing trany or clutch work but i know what you mean about the 250k
also i had a 2000 r6 that had stator and regulator issues too, around 17k
i hope these numbers posted can be achieved on my bike. I usually don't hold a bike long, but I'm liking the '08 R1. although there might be another bike in the stable next to it soon, this one is a keeper anyway
...Uhhh, You are underestimating mileage when it comes to cars at least... My car {'94 sunbird} has 110k miles, and is still going strong and smooth...
...Anyways, this is a loaded question....It depends on how you take care of it and ride it...
...100k miles is easy, assuming you don't crash first...
well i got 126,000 km's ( 78 292 miles) out of my 03 before i did a head gasket... could just whack another gasket on and keep going - compression and oil consumption etc were still fine till i did the gasket - which only blew because of a bit of lack of maintenance on my part (hadn't replaced coolant for a long time)
doing a full rebuild now because i can :)
I think you're asking for information that won't answer what you're looking for. Meaning you want stats but that really won't answer how yours will do or be... All mechanical things need to be taken care of, and if they are taken care of then they'll last barring accidents and mishaps. If you're bike was built correctly at the factory which is statistically most likely and you take care of it as per the instructions, the bike should last forever. Of course in the real world, you tend to have accidents or get abusive which adds stress and wear to parts which shorten specific areas of the bike. Too many wheelies, head bearings tend to age.
Too many drag races, clutch plates and chains wear out.
too many canyon days, tires and suspension wear out.
etc etc...
I have in my garage right now a 94 CBR 900 rr. It has about 40k miles on it. I am the 3rd owner, I crashed it about 8 years ago. Rebuilt it 4 years ago. I don't ride it and it has been sitting in the garage for the past 4 except for one ride here and there. I didn't even have a battery tender on it. Several months ago, I just put the charger on for a couple hours and boom, started fine, smoked a little but after she was warm, she was good to go. This is on an 8 year old battery. Parts will break with use but the bike's longevity is mostly up to you.
#23 ·
For what it's worth, I bought my '03 with 54k on it. The history of the bike is unknown to me but judging by the Corbin seat, blind spot mirrors, and jacket/glove warmer, I'd guess that it was an older guy's commuter. I'd guess that it was probably serviced regularly.
Now, it has 60k on it and it still starts, runs and shifts perfectly.
I just hit 34K on my 06' last weekend. Never had a problem with it. Maintenance is key.
Have you signed up with the Dragon Squadron yet?
#26 ·
One way of looking at this question is to consider that each engine will spin x number of times before it decides to $hit the bed. x as everyone has discussed is dependent on many factors primarily dealing with usage and maintenance detail. The faster you spin your engine the sooner you will hit x. My suggestion is to utilize gears 5 and 6 as often as possible without bogging down the engine. A warning about "bogging down an engine": If you were to draw a force vector diagram of a cylinder you will see the resultant vector shoots out to the side which will in turn lead to wear and tear of piston rings/walls etc. Long term doses cause lower compression to occur. We all know engines need three things in order to run: ignition, fuel, and compression. Lose any one of those and you're out of luck.
On a side note...I've actually got a full stator assembly for a 2004 R1 if anyone is interested...
#32 ·
Met a guy yesterday with a 2001 R1 with 100,000kms on it. He says never let hime down, all his done are the regular maintaince and frequent oil changes.
The bike looked really clean and you couldnt tell it had that manu kms on it.
I think a well maintained bike will last for ages. Alot of people just neglect them and they end up looking really ratty.
#33 ·
:bs 62k miles without the Regulator Rectifier going out once... Highly doubtful.
#41 ·
geez... all these 5 digit numbers freak me out.... i only had 7K miles on it before i sold it.
exception on me riding it, the bike was well maintained on a regularly basis. i think mine would've lasted a lot close to 100K also....:)
