Status
Not open for further replies.
What are normal operating temperatures for 07-08 R1?
35K views 18 replies 18 participants last post by  KoPan
what would you guys say is normal temp while running in city traffic...
not gridlock but you know a bit of stop and go, 30 mph etc..
yesterday my 07 R1 started running at 232 and my left leg started to burn a bit, i don't know if the fact she is not broken
in yet has anything to do with it, still under the 600 miles. :confused:
The 07 R1 runs a bit warm. I would check your antifreeze. My 07 was at the minimum mark so I added some to bring it up to the maximum level. As long as the temp light does not come on then you should be ok. Your leg is a different story.
I hear you guys, it makes you think but i mean in the book it says that those are all normal operating temperatures. basically if the light comes on something is wrong. my 07 R1 has 117 miles on it and i have driving it around town cuz of the stop and go, it will go right up to 223 kick on the fan and back down to 208 then right up again... but my R6 was like that too so.. shes basically saying open me up and stop pussy footin around :thumbup
Yea, my bike seems to be always in the 220+ in the city. If im sitting around then it will hit the 230+ when i shut off it reaches 240's. Seems to be normal. But ima try running engine ice in it in a couple days. and hopefully get a new Y pipe soon as well.
Wheat and I were being serious when we said gut the cats and run distilled water and water wetter. It really makes a big difference. If you have an 07 and don't like your legs burning this is a must mod. It is not difficult and the "how to" is simple to follow if you want to do it yourself or if you want to have someone else do it for you. :horse:
In town going stop light to stop light 224 degrees then fans kick on. Out of town about 160-185.
I agree with you guys that gutting the cats and running Water Wetter with distilled water will help drop temp some overall, but if your in town going light to light on a hot day the fans are still going to kick on no matter what you do.
I put in Engine ICE this weekend and I very happy with the results. I noticed an average of 5-10 degress Celsius less then before and less then my friends bike. Checking each others temp 6 different times. (he has same bike and we doing same speed)
Save
#17 ·
Should fans be on when starting?
I talking about a warm engine after long commute. If Engine temp is above 200 and I stop for gas, the fans turn on when ignition keys is turned on. Fans suck up alot of voltage. Makes it hard for warm bike to turn over with fans blowing I think.
If I stop for gas or if I stall with clutch at a light, I have to bump start it.
#18 ·
Fans will turn on if its above appx 205 (not sure the exact temp I'd have to look at the manual) as soon as you turn the key to on. You might need to see about a new battery or the charging system if it still doesn't start with a good battery.
#19 ·
Fan kicks on at 221-223F
I think you should check your battery/charging system for startup problem. Mine's with a new battery and starts like silk even with fans/HID lights on.
My normal temp in rush hour traffic is around 205 at 40-60kmh, and 223-228 at stop/traffic light stop
Save
Status
