What is the bad about lowering an r1?
4K views 49 replies 27 participants last post by  sircharles1
I just got my 1st r1, I am kinda short so I was thinking about lowering it.
I can ride it okay as is but, I don't feel 100% comfortable with it. I was wondering what are the down sides to lowering an R1??
Any info would be great.
:fork
Handling is diminished, ground clearance is lessened as well as lean angle is worsened.
Less ground clearance scares me. Flattening ti headers is not how you want to end your ride.
How bad are we talking here? Are you teetering on your tippy toes when you're stopped?
Man up Ride it at stock height, Learn to handle it. Just not a good idea to lower the bike. But if you most keep the geometry the same if you lower the front 5 cm lower the rear the same, only go as low as you must and not one Centermeter more.
if you do lower your bike you will want to get a shorten kickstand or shorten yours.
Should be noted that if you are looking to drop a half in or so - shaving the seat helps. there are threads on how to do it and its sucess.
5' 4" here. I had mine lowered for a time, but I eventually put it back. Didn't like the handling changes at first, but I got used to it.
I changed it back because the link I used had bushings instead of needlebearings like the stock link. After about a month of riding, that thing started squeaking something fierce. Might have left it alone if it hadn't been for that damn squeaking. I had also heard people had issues with aftermarket links breaking. Definitely don't want THAT happening.
#32 ·
The problem with lowering the bike with intentions of changing back to stock is simple. You'll get used to it lowered. Then when you change back you're starting over again, it's mostly a waste of time.
Just take it really easy at first in low-speed/light/parking situations. Get some proper boots and be mindful of slippery/sloped surfaces. Take your time. Practice if you need to!
FYI my GF is 5'4" and rides a 600rr at stock height fine. (lots o leg though :) ) If the weight of the r1 (considerable at your size) is an issue hit the gym!
#36 ·
I'm 5' 9"ish and when i first got on an R1 i stood on my tip toes. after awhile I learned how to sit correctly and lean the bike slightly at stops. plus wear boots...i was squidly when i first got on sportsbikes. i wear boots now and it helps out too. i can firmly plant both feet on the ground. when my dad takes my bike for a spin around the block he complains its too tall for him....and hes a couple inches taller then me.
#37 ·
Dont lower it, it'll ruin what the bike was meant to do. BTW I saw you are in charlotte, I'm in Winston-Salem a lot of the time and sometimes in charlotte. Let me know if you wanna ride ever
#38 ·
IMO, much of the apprehension is in your head. I'm only 5'6 and yes the R1 sits higher then say a Suzuki but once you get used to being on your toes a bit, you'll eventually become more confident. As many others have said, get yourself a pair of Doc Marten boots or similar and or shave the seat a bit. Ride safe
#39 ·
....I'm 5'2", my inseam is like 28" or 29", something stupid short.
My R1 is not lowered, I can touch the absolute tips of each foot if I had both down.
The key is balance, I rarely ever use both feet to balance the bike but almost always slide to the side a little and plant one foot down. Once someone gets use to the feeling of the bike (when stopped/stopping) then it will be simple to balance it.
Now moving it around while on the bike is a different story :lol
