Yamaha's oil filter wrench? Is it really needed?
4.6K views 40 replies 20 participants last post by  Sabian
As the tiltle says.. Is it really needed.. the dealer is trying to rip me say it will cost me 45-50 bucks!! How many of you brought it and for the rest of you what do you do?
Thanks.
I also got a generic one and it works just fine. you don't need it, but it makes it MUCH easier to get the oil filter off :yesnod
hmm, I dunno, I use an old leather belt when getting a oil filter off that I haven't originally installed. On really tight ones I punch a screw driver through it for leverage....but i think a generic wrench would make things much easier/less messy.
On a side note:
From that point I do them up by hand (with some kind of old school rule of an a turn and a bit once the gasket touches etc) enough so they won't leak but aren't hard as hell to get off the next time.
I changed my oil/oil filter yesterday and the previous filter I had installed last year was easily undone by two hands and had not leaked....
Dude just take your filter to Auto Zone or any auto parts store it doesn't freaking matter what brand it is it's a damn oil filter wrench... :crash
There are many cars that use the same size filter as our R1s do so they have them readily available and for like $10 bucks.
I did that once. After I burned my hands on the headers I got the socket wrench kind.
#11 ·
I've bought about a half dozen little different types of filter wrenches. I found a matching set of strap wrenches and now use the smaller of the set specifically for my oil filters. Between the three, I'm changing oil somewhat frequently. It's been a breeze with the strap wrench. I don't even use the others anymore.
send that my way :flex:
Just use a screwdriver for the first time you need to remove the filter (cuz the dealer probably torqued the sh!t out of it) and after that just hand tighten.
#24 · (Edited)
What's wrong with using a screwdriver to remove a stubborn filter? Ideally you should have the proper size filter wrench on hand, but I can't see anything wrong with using a little creativity with a screw driver.
Can someone please explain why this is so bad? <---No sarcasm intended.
#31 ·
There's the potential for screwing up the threads on the oil filter stem while hammering in the screwdriver, plus, you're putting a good deal of bending moment on the filter stem too which could potentially cause it to crack (never heard of this happening though).
Besides, a strap wrench is cheap and very easy. I'm with Dan on this one.
I always hand tighten the filters on my car/truck, but I read multiple times you are supposed to crank down a little on your oil filter. I am going to guess that is because the last thing you wan is a mojor oil leak on your bike. (Or any leaking for that matter) That would go right under your back tire!:drunk:
#34 ·
this thread is better than a "which oil is best" thread
#35 ·
End of a nylon tie-down and a pair of channel-locks, presto instant strap wrench.
Yeah, I'm cheap :yesnod
#36 ·
i had to use the screwdriver method to get the first one off too. The only way it will damage the thread is if you are a doofus and hammer the screwdriver into the thread instead of into the far end of the filter.
+1 for doing them up and removing with the hands god gave you
unless you are a pussy :crash
