Yamalube and motul
15 reading
59K views 120 replies 16 participants last post by  Fast Eddy
So my 14 R1 has 10k miles on it. So time for that oil change. Wouldn't yamalube in theory be best for a Yamaha? Also went to motul website and it recommends the 7100 or 5100... why wouldn't it recommend the 300V?
I'm using 300v for the first time.
Been using Amsoil 10w40 for a long time.
I like them both.
What I have noticed is that Amsoil gets darker in the site glass a lot fast which indicates to me that it has a LOT of detergents that clean the engine.
The 300v stays green for a while and has another shifting.
Not sure if I'm going to go back to Amsoil or not but I do know that Amsoil is doing something in there to keep the engine clean.
because it's a race oil that probably isn't designed to last more than 3k miles. yamalube definitely suggest not using their race oil for street use.
it says it will not perform through a full service interval. I guess it lacks some kind of ingredients to clean the engine for extended service intervals.
yamalube made my engine quieter than the 10w40 motul 7100 I was using. this time I tried the 10w 60 7100. so far it seems a little quieter. (mellowing the yamaha tick)
#22 ·
What people call lean theses days is not lean if your plugs and exhaust aren't white and your not running excessively hot your not running too lean.so many half ass tuners out there theses days just trying to get the bike off the Dyno and get payed they take the wrong route and run everybody rich because when they run proper afr's people complain about abrupt or aggressive throttle response and they don't want to are lazy or don't know how to properly tune that by going into ignition timing
#23 · (Edited)
Been using 300v in my 05 since roughly when it had around 2k miles on it. Im no oil expert but here is my report from my last oil 3 changes. On my last change they advised me to check my air filter and sure enough it was filthy. (BMC race)
  • Like
Reactions: DarkHorse
#27 ·
Find another tuner one2 reputable tuner according to who word of mouth a guy that knows a guy someone people on the internet rave about?do they build and tune any engines that have won championships any tuner who recommends 12.8 that low is an idiot and most people don't know any better the reason you like that afr is because you think it's giving you smooth throttle when it's not your flooding it what is your ignition tables if he didn't tune that another good reason to look for another tuner.idk how long you have been running it like that but next time you change your plugs take a scope camera look in your Cylnders and I guarantee you you'll see scuffs all over in the up and down direction.bump your afr's to 13.2 and start adjusting your ignition to give you the throttle response you like don't flood the engine to do it.post photos of your exhaust is it black?
#58 ·
I'm not trying to be a dick at all one2 I'm don't wanna see you damage your engine heavy black residue in the exhaust is wasted fuel your not burning it.just please check your cylnder walls when you change plugs with a camera their cheap 12.8 is to much that low go higher and pull ignition timing back in small increments if the throttle feels abrupt.im honestly just trying to help.be safe and have fun one2
#52 · (Edited)
I found a good read: Racing Oil vs. Street Oil: Know the Differences - EngineLabs
Seams as if Amsoil gets dark quicker like a lot of people are clearly experiencing is because it has really good addictives that keeps the engine cleans.
Looks like Amsoil 10w40 is a keeper. :)
And it's not just us. I did a search a long time ago and found that many people are experiencing the same thing with Amsoil in cars, trucks, dirt bikes, and all other engines.
#53 · (Edited)
they do mention motors with flat tappet cams need oils like racing oil because they can protect it better. our bikes have flat tappet cams. however I'm sure even the street motorcycle oils will meet these needs. which is why I wouldn't use a car oil in my bike. never have never will. but we will still have the guys that argue it meets api xxx or jaso xxx so it's good enough.
#62 ·
i broke my engine in with the basic oil it comes with like you supposed to to help everything seat then changed out the oil for 300V at the first oil change because i was so pleased with it from my previous bike. the 300V is always clean and keeps its same basic colour for my engine. the 300V is supposed to have the best rating you can for how well it lubricates gears and other parts to keep them from contacting metal to metal its supposed to retain the film even under high pressure. i believe thats part of why it stays clean the engine isn't wearing out and dirtying the oil.
i just pulled the engine on my '15 R1M and tore it down to do my motor build and the inside of the engine is SPOTLESS. no black, no dirt, no wear marks on any of the transmission gears nothing on the shift forks the engine looks like it has maybe a couple hundred miles on it. some slight marks on the main journal bearings but i believe thats from the initial cold starts in winter to warm it up once a month.
i was told that the 300V doesn't meet yamahas exact spec for what they will warranty for whatever reason, but i know ducati use the 300V in their bikes it was what dealers where i am used as the standard so that leads me to believe its just yamahas criteria isn't met and not that theres an issue with it lasting.
as for the oil getting black from running rich thats more of an issue if your rings aren't seated properly. as zdamans oil analysis showed the fuel in his oil is negligible. its more concerning the oil mist going into the air box and causing carbon in the combustion chamber. he's running his oil more miles then a lot of people are and changing it once a season so thats even longer then the recommended 6 month intervals and its still within spec. thats good to see in hard facts. id say the colour change is the additives just darkening with the heat cycles. all the facts and studies and data sheets are out there on all these oils its probably better to look those up then get hearsay and urban oil legends from a forum.
