I have not seen any specific info on this from yamaha, and I am pretty interested to see how exactly it's laid out. Can you give a map of cylinder activity vs crank rotation in degrees? If it had 8 cylinders at 90 degrees it would be easy to complete the 720 degree rotation. With only four, you can either burn all four in rotation and coast through the second or try and split it up, which gets confusing fast..
Here's one I MADE UP, just to give you an idea what I'm asking.
EDIT: CRAPP I guess my spacing didn't transfer into the post making these little charts useless and unreadable.
imaginary motor with 90 degree spacing
0 90 180 270 360 450 540 630 720(0)
1 3 2 4 Compression
2 4 1 3 Exhaust
Imaginary motor with 180 degree spacing
1 2 4 3 Compression
4 3 1 2 Exhaust
1 3 2 4 Compression
2 4 1 3 Exhaust
1 2 4 3 Compression
4 3 1 2 Exhaust
